6500
May 29, 2007 2 Replies
ios 12.2(17r)S2(Fc1)
hi, i am beginner i wish interconnect two 6500 router by gigabit ethernet with no ip address like a switch
does any body know how do that ?
So connect them. Either configure the ports as access ports (set vlan XX mod/port), or configure the ports as trunks. The commands will be slightly different if its native ios code versus catalyst, but this is very straightforward. What specific part are you having issues with? Also need a crossover since its switch to switch.
hi, thanks for your response
i have configured my port in switch access mode but i think youre are right i should configure port in trunck mode
i have'nt use cross cable becaus it was fibre connection
"Trendkill" a écrit dans le message de news: snipped-for-privacy@q66g2000hsg.googlegroups.com...
