5350 can't use G711 payload type for fax pass-through??
Apr 04, 2005 2 Replies
Walter Roberson
:I am trying to configure a Cisco 5350 with 12.3 software for fax :pass-through (bypass?) mode. I use this command: Possibly a Cisco 3550 instead?
I am trying to configure a Cisco 5350 with 12.3 software for fax pass-through (bypass?) mode. I use this command:
fax protocol pass-through g711ulaw
On my Excel gateway, when I switch to fax bypass mode, it switches to G.711 uLaw and uses the standard payload type for G.711u, but Cisco uses PT=96.
Is there another mode where the 5350 will not use a PT in the dynamic
96-127 range for fax bypass/pass-through, still switching to G711u/A but using that codec's PT?
I have worked with 3 different vendor products other than Cisco, and when they switch to bypass, they use the G711 PT. This is the first time I have seen a dynamic PT used for this feature. Usually, I see it used for RFC 2833 digits or RFC 2198 RTP redundancy only.
Thanks,
Greg
In article , Greg wrote: :I am trying to configure a Cisco 5350 with 12.3 software for fax :pass-through (bypass?) mode. I use this command:
Not a 3550, but not a 5350 either. It's a 5300 with 12.3(13) loaded.
"IOS (tm) 5300 Software (C5300-IS-M), Version 12.3(13), RELEASE SOFTWARE (fc2)"
So the question remains...
Is there another mode where the 5300 will not use a PT in the dynamic
Thanks!
