4006 PSU pin out
Feb 01, 2006 2 Replies
Hi I have a 400W PSU from a Cisco Catalyst 4006 and would like to know the pin out for the rear connector. In particular I am looking to identify the sense pins as the unit will not power-up with out these sensing the
+12v rail. For information sake I am trying to use this 33.3A 12V psu to power and amateur radio rig!
Many thanks for any help you may be able to provide.
Colin
I know of no reverse engineering that's been done on Cisco's power supplies. If there is, I happen to have several catalyst 5500 power supplies that I'd be willing to ship to anyone for a minimal amount.
-however- My suggestion to you is to save your frustration with it and buy an old PC ($5 - $10) and strip it's power supply. If the PC is not too old, it should have a decently large power supply. There are several web sites that outline the use of ATX power supplies for other purposes.
J.Cottingim
Hi Colin,
You may wish to investigate the Cisco Power Supply Replacement Inventory:
Sincerely,
Brad Reese BradReese.Com Cisco Engineers
Hendersonville Road, Suite 17 Asheville, North Carolina USA 28803 USA & Canada: 877-549-2680 International: 828-277-7272
