3750 problem
Mar 24, 2007 4 Replies
Jump to replies (4)
Dear All,
I'm having a problem with a 3750 L3 switch here. The internet uplink is in port 1/0/1 so obviously the default route is set accordingly. there are 2 vlans defined for public/private network and my firewall is connected to both vlans - one interface for each. I want to route traffic thru my firewall and that one should be a default route as well. now the problem is that i cannot have two default routes in one device.
any suggestions?
thanks, Alex
Hi Alex,
Disable the routing on your 3750 by typing the following command "no ip routing". And let your Firewall route the traffic to internet.
BR Marc.
in that case my firewall has to be connected to the provider, right?
i was thinking about the policy map, to change next hop based on source route:
access-list 101 permit ip any 192.168.20.0 0.0.0.255 route-map FIREWALL permit 100 match ip address 101 set ip next-hop 192.168.16.44
but when i try to add ip policy-map to the incoming interface it does not have this command enabled. isn't it included in the ip-base image? what image should i use then?
thanks a lot, Alex
Alex Turtois napisa=B3(a):
I think that - profiling for routing and PBR exist only in EI image.
