2900 switch question
Sep 06, 2007 5 Replies
Jump to replies (5)
have WS-C2924M-XL-EN version 12.0
The switch handles traffic both on routable IP 206.x.x.x and non-routable
10.x.x.x. A 2620 router with two NICs nats the 10.x.x.x All Microsoft stuff lives on the 10.x.x.x network and each node in the VMS cluster has two IPs, one for each network. The switch which I access through the console has an IP on the 10.x.x.x network.
I would like to be able to telnet to the switch from the internal network, but I get following message
Password required, but none set
I have not set any password, when I connect through the console I give enable as the password. I presaume I need to give it something other than default. The only thing I see that comes close is SET, but Switch#> SET ? % Unrecognized command
TIA Tom
You are in a IOS based switch, so set won't get you anywhere. Do a config t, line vty 0 4, and then password . Hopefully that gets you where you need to be.
You have to set a password on the telnet line:
conf t line vty 0 15 password Cisco login exit write mem
Trendkill is correct, it should be:
conf t line vty 0 4 password Cisco Login exit write mem
New question, got a second identical switch which has 2 X2931 Gbit modules with SX GBICs the opriginal one had one such module which had originally hosted a Gigastack GBIC
I tried putting in a SX fibre GBIC in original unit
when I look at the int on both, the old one says
Auto-duplex , link type is autonegotiation, media type is unknown 0
whereas the new on says
Auto-duplex , 1000Mb/s, media type is SX
How to get this to work?
Can these modules be removed with power on?
My stupidity, sorry, I had the cables reversed.
However, still curious about media type, the are both version 12.0
