2811 and wic-1adsl
Apr 22, 2005 6 Replies
Jump to replies (6)
i=B4m having a problem with the above configuration which nobody has been able to help me.
the following is my configuration
Router 2811
IOS:C2800NM-ADVIPSERVICESK9-M, Version 12.3(14)T
Configuration: ## not sure if these are needed? vpdn enable
vpdn-group pppoe request-dialin protocol pppoe ################################
interface FastEthernet0/0 ip address 10.10.10.1 255.255.255.0 ip nat inside ip tcp adjust-mss 1452 duplex auto speed auto no cdp enable no shutdown
interface ATM0/0/0 no ip address no atm ilmi-keepalive dsl operating-mode auto no shutdown
interface ATM0/0/0.1 point-to-point pvc 0/35 pppoe-client dial-pool-number 1
interface Dialer1 ip address negotiated ip mtu 1492 ip nat outside encapsulation ppp ip tcp adjust-mss 1452 load-interval 30 dialer pool 1 dialer-group 1 dialer persistent no cdp enable ppp authentication chap pap callin ppp chap hostname &&&&&&&&&& ppp chap password 12345678 ppp pap sent-username &&&&&&&&&& password 12345678
ip classless ip route 0.0.0.0 0.0.0.0 Dialer1
ip nat inside source list 1 interface Dialer1 overload
access-list 1 permit 10.10.10.0 0.0.0.255 dialer-list 1 protocol ip permit
When I turn on the debugging, I can confirm that the wic does train successfully (SHOWTIME result) with the dslam at the operator.
BUT!!!! When I turn on ppp debugging nothing happens. This tells me that there is a problem within the dialer I think.
I have also confirmed with the operator which dslam they are using (there=B4s being an alcatel), since I have read that only certain ones are compatible with the wic-1adsl. Our operator does for example also use the siemens one which is not compatible
Hi Fernando!
While I am not entirely sure with regards to PPPOE, I use a ADSL WIC with PPPOA and under the PVC settings one has to specify the encapsulation settings ie aal5mux,aal5snap whichever one your ISP has specified.
Hope this helps.
Rob
well i leave it as default. aal5snap. i have installed many cisco adsl routers before, all soho line. and with these i have left them as well as default. i presume soho is also aal5snap.
but as i mentioned in my previous post, the wic-1adsl does train successfully with the dslam. the result is "SHOWTIME".
BUT when i try to debug ppp nothing happens. therefore i assume that the problem lies within the dialer configuration.
please someone help me! i have no hair left.
Ok, sorry about that I wasn't aware that it was a default statement.
Would you not have to assign the PVC as a member of the dialer pool 1 ie (dialer pool-member 1) thus binding it to the dialer interface?
< pppoe-client dial-pool-number 1> specifies interesting traffic as specified by your access-list 1, but I think the pvc needs to be bound to the dialer interface with as your dialer 1 interface is assigned with: int dialer1 dialer pool 1 dialer-group 1
yes rob. i have done that. see my config above.
