PPPOE for DSL
Nov 07, 2005 1 Replies
I have at Cisco 2620 running 12.1 with a 4 port IMA card. I have an ATM link to my DSLAM and am trying to get PPPOE workng but am having no luck. Any help would be appreciated. I would consider paying a consultant.
Thanks
here are two sample configs, one with atm interface and ppoe, and one with an ethernet interface and ppoe. search the cisco site for 800 series router configs for atm and ppoe information.
cisco atm ppoe vpdn enable
no vpdn logging
vpdn-group 1
request-dialin
protocol pppoe
interface Ethernet0
ip address 192.168.100.1 255.255.255.0
ip tcp adjust-mss 1452
ip nat inside
interface ATM0
no ip address
no atm ilmi-keepalive
pvc 8/35
pppoe-client dial-pool-number 1
dsl operating-mode auto
interface Dialer1
ip address negotiated
ip mtu 1492
ip nat outside
encapsulation ppp
dialer pool 1
dialer-group 1
ppp authentication pap callin
ppp pap sent-username sohodyn password 7 141B1309000528
ip nat inside source list 101 interface Dialer1 overload
ip route 0.0.0.0.0.0.0.0 Dialer1
access-list 101 permit ip 192.168.100.0.0.0.0.255 any
------------ ethernet config with ppoe configuration for Spoke1 router using PPPOE
Spoke1#sh run Building configuration...
Current configuration : 2829 bytes ! version 12.3 no service pad service timestamps debug datetime localtime service timestamps log datetime localtime service password-encryption ! hostname spoke1 ! boot-start-marker boot-end-marker ! enable password xxxxxxxx ! !-create username for administration
username user password passwd no aaa new-model ip subnet-zero ! !-set IP addresses not to be used for DHCP
ip dhcp excluded-address 192.168.6.1 192.168.6.99 ! !-define DHCP scope and parameters
ip dhcp pool spoke1 import all network 192.168.6.0 255.255.255.0 default-router 192.168.6.1 dns-server 4.2.2.2 lease 0 2 ! ! ip name-server 151.164.1.8 ip audit notify log ip audit po max-events 100 ip ssh break-string ! !-enable vpdn to allow creation of dialer interface to support pppoe
vpdn enable ! ! !-create vpdn group for pppoe encapsulation
vpdn-group office request-dialin protocol pppoe ! no ftp-server write-enable no scripting tcl init no scripting tcl encdir ! !----configuure IKE police and pre-shared key for each peer.
crypto isakmp policy 10 hash md5 authentication pre-share ! !---- Preshared key for hub peer
crypto isakmp key 1cisco address 10.1.1.1
!----Keepalive added to help resolve problem of tunnel timing out and not restarting
crypto isakmp keepalive 30 ! !-----lifetime added to help resolve problem of tunnel timing out and not restarting
crypto ipsec security-association lifetime seconds 28800 ! !--configure ipsec parameters for transform set crypto ipsec transform-set spoke1 esp-des esp-md5-hmac crypto ipsec df-bit clear ! !---create map to define tunnel traffic ! !-tunnel to hub, specify number sequence, peer, transform set, and acl to include the !---private network to private network traffic in the encryption process
crypto map spoke1 10 ipsec-isakmp set peer 10.1.1.1 set transform-set spoke1 match address 110 ! ! ! !-apply NAT inside to LAN interface, add ip tcp adjust-mss 1400 to reduce packets !--using pppoe encapsulation
interface Ethernet0 ip address 192.168.6.1 255.255.255.0 ip nat inside ip tcp adjust-mss 1400 hold-queue 32 in ! !-set pppoe enable, and pppoe clienet dial pool acl to match LAN
interface Ethernet1 description ppoe to vendor Inet no ip address ip nat outside no ip route-cache no ip mroute-cache duplex auto pppoe enable pppoe-client dial-pool-number 1 no cdp enable ! interface FastEthernet1 no ip address duplex full speed 100 ! interface FastEthernet2 no ip address duplex auto speed auto ! interface FastEthernet3 no ip address duplex auto speed auto ! interface FastEthernet4 no ip address duplex auto speed auto ! !---Create dialer interface for PPPOE connection, apply crypto map on dialer interface, !-- lower mtu due to pppoe restrictions, apply encap ppp, set dialer pool and dialer group, !--- configure authentication, pap or chap, if not sure configure both
interface Dialer1 ip address negotiated ip mtu 1492 ip nat outside encapsulation ppp dialer pool 1 dialer-group 1 no cdp enable ppp authentication pap callin ppp chap hostname spoke1 ppp chap password 111cisco ppp pap sent-username spoke1 password 111cisco crypto map mymap ! !-set NAT for LAN traffic using overload
ip nat inside source list 102 interface Dialer1 overload ip classless ip route 0.0.0.0 0.0.0.0 Dialer1 ! !---specify route for LAN to LAN private network traffic to each peer
ip route 192.168.5.0 255.255.255.0 Dialer1 ip http server no ip http secure-server ! !-acl 1 -set LAN traffic to be allowed on your dialer interface access-list 1 permit 192.168.5.0 0.0.0.255 ! !---acl 102 exclude LAN to LAN traffic from being included in NAT
access-list 102 deny ip 192.168.6.0 0.0.0.255 192.168.5.0 0.0.0.255 access-list 102 permit ip 192.168.6.0 0.0.0.255 any ! !-acl 110 define interesting traffic form spoke1to hub
access-list 110 permit ip 192.168.6.0 0.0.0.255 192.168.5.0 0.0.0.255 ! control-plane ! ! line con 0 exec-timeout 120 0 no modem enable transport preferred all transport output all stopbits 1 line aux 0 transport preferred all transport output all ! !-set login via telnet using local information
line vty 0 4 exec-timeout 30 0 login local transport preferred all transport input all transport output all ! scheduler max-task-time 5000 ! end
