2811 and built-in fa / vlan
Jul 24, 2007 3 Replies
Jump to replies (3)
How do I asign a vlan to the built-in fa 0/0 or fa0/1 of the 2811 ?
Currently I can only assign VLANs to the HWIC 4FE module on this router with the switchport command, but the fa0/0 and fa 0/1 does not understand the switchport command.
Thanks for your advice,
DT
You can't as these are layer 3 Interfaces, however they can be used to create 802.1q trunks to other switches.
James
James, thanks for the info. I can then move the trunk port currently on one port of the hwic to the fa 0/0 and then assign the vlan to that port on the hwic.
DT
I'm not 100% sure if you will be able to configure the same VLAN's on an external switch as are on the ESW module. There was discussion regarding this a few days ago - search for the post titled "Trouble with 1841 and 4ESW Switch"
James
