2 x PIX 506E's and an 837
Mar 10, 2005 4 Replies
Jump to replies (4)
Help please.
I have spent most of the day putting together what I considered was a very simple config. I have 2 x PIX 506's connected into the 4 port switch on the back of a Cisco 837.
I wanted to create a tunnel between both PIX's. My IP scheme is as follows:
PIX1 Inside - 10.1.0.0 /24 PIX1 Outside - 80.X.X.X /29
PIX2 Inside - 10.2.0.0/24 PIX2 Outside - 80.X.X.X/29
837 - Ethernet 0 -80.X.X.X/29 Dialer0 - IP Unnumbered Ethernet0 NB I put static routes on the 837 to the PIX1 and PIX 2 LAN addresses.
On the PIX's I believe that I have done everything in the correct way. The content has been omitted because it's the access-list that's the problem. I am not seeing any hit-counts - The statement on PIX1 (reveresed for PIX 2) is as follows:
access-list traffic permit ip 10.1.0.0 255.255.255 10.2.0.0 255.255.255.0
The pre-shared keys, DH group, encryption, peer addresses, Crypto map statements etc for ISAKMP / IPSEC all appear to be OK.
Is there an issue with using an 837 in this config.
Regards
-- Darren Green
In article , Darren Green wrote: :I have 2 x PIX 506's connected into the 4 port switch on the :back of a Cisco 837.
:The statement on PIX1 (reveresed for PIX 2) :is as follows:
:access-list traffic permit ip 10.1.0.0 255.255.255 10.2.0.0 255.255.255.0
Is that a typo? You have missed one of the octets on the mask after 10.1.0.0 .
Have you made sure to nat 0 access-list the traffic between the two? If not then the crypto 'match address' ACL is never going to match, because the 'match address' ACL is examined *after* translation: if you haven't exempted the traffic from translation then the source IP that the crypto map would see would be the 'global' address.
Walter,
Thank you for your reply so quickly.
A- Yes it's a typo, I thought that I had double checked it.
A- I had originally put in the commands: nat (inside) 1 etc and global (outside) 1 interface. I ended up taking them off in the end during the troubleshooting phase. I completely overlooked the nat 0 command - appreciate the pointer.
Regards
Darren
have you got a static translation configured to allow each network to address the other?
Regards
I didn't have a static translation but I did get the opportunity to enter the nat 0 command and everything is now working fine.
Thanks for the replies.
Regards
Darren
255.255.255.0
