reset default factory settings on cisco router
Apr 26, 2006 2 Replies
is there a way to reload factory image on my cisco 806 that came loaded with setting from someone else and i'd like to wipe all that off and setup the web setup admin for this router.
can someone tell me the best way i should go about doing this, or is there a web site that someone knows of already that will walk me through this?
i've tried the 'erase start' that someone had suggested but that did help much, but thanks for the suggestion.
Thanks for your time.
Hans means:
erase startup-config reload
