DHCP setup on cisco 806
Apr 28, 2006 0 Replies
so the other day I needed to reload the factory settings on my cisco 806 so i did so using the 'write erase' command, which worked fine, but when the setup came up after the reload i'm not sure on how to setup e1 to get and IP from my cable modem and then setup DHCP on the 4 ports(e0) So i'm sure this is a simple fix to some of you guru's but i'm just a little stuck and not to farmiliar with the cisco IOS, so any help is greatky appreciated,
btw, kudos to all the responses in the past on this news group!
Thanks
