Resetting a Switch to Factory Settings
Nov 06, 2008 3 Replies
Jump to replies (3)
I have a couple of 2900 series switches which we have inherited and need to set them back to factory settings so I can start from clean with them.
Is there an easy way of doing this?
K schrieb:
Yes.
Depends ... if you have the passwords for the switches you may use write erase and reload
If not you will have to reset the switch at boot-time.
Search the cisco web site and you will find some tons of docs about that.
Klaus
In all cases you need a console cable.
If they are 2950 or (2960 - these are the current model.) Not -XL at the end.
You need to - connect up console log in if necessary go to enable mode with the "enable" commmand "write erase" - this is the old command and there is a more descripitvely named one as well. but I dont know what it is. "reload" - or just switch off
Was there a 2900XL series? If it is one of these then the above may work or it may be different. I forget.
If there are passwords and you dont know them you will have to do password recovery first. Search the cisco web site for the words
"model-no" password recovery
This should turn up the correct document.
erase startup-config
also, delete flash:/vlan.dat to clear the vlan database.
This should work with most, if not all, of the IOS based switches.
yes. the same procedure should work.
