cisco query??
Jan 17, 2006 3 Replies
Perkowski
You can uplink to any switch. If you are going to go with a "cheaper model", go with a 3Com switch........I use them all the time, and I love em....
hi We're trying to extend our structured network ie. add more points/ floor outlets, we currently have a cisco cataylist 2950 with all our 24 ports in use. we will need to uplink to another (new) switch to give us more capacity.does this need to be another cisco router?? or can we use another brand (cheaper) to cascade of our exsisting router?? and just disable dhcp thanks to one and all for any pointers.
This is not good. You should always have spare ports for testing or if one goes dead.
I would definitely consider a cheaper cascade switch, especially if the new space/outlets is used for relatively lightly loaded user workstations. This can also save considerable cabling run. Just put a switch in the most convenient telco closet. I've also seen people hang them on walls.
Many people only have servers and switches plugged into their Criscos. All workstations a plugged into switches. This usually works well unless several workstations are heavy bandwidth users and are hitting different servers.
You shouldn't need to disable DHCP. Switches will pass it through, and the Cisco should be able to serve multiple MACs/IPs on the same port (unless configured otherwise for security).
-- Robert
a 2950 is a switch not a router
I would have gone for another 2950 maybe the 48 port verson or another
24 port
As some one sugest a cheaper cascade switch one posibility would be to get 1900 second hand switches and put some of the hosts on those depends if they realy need 100 Mbs
