Router port light is always on
Feb 15, 2005 3 Replies
Jump to replies (3)
I have a netgear router with four ports, usually the port (1-4) usually lights up only if one of my four computer is on... but i noticed that port 1 which is my main computer... the port light in my router is always on even when (1) computer is off... it wasn't like that before... i know its not my router... cuz i hav 2 routers and tested it... its d same... so is there somthing wrong w/ my cat 5 cable? or NIC ? i do get internet connection from it btw...
  1. (Wireless)Netgear MR814 v2 (main)
  2. Belkin Router (extra)
Windows XP home service pack 2
It's possible your NIC is powered up even when the computer is turned off. Nothing wrong with it. -Dave
how do i change it??? ... cuz it wasnt like that before....
Why bother changing it? If the computer is off, then the NIC can't do anything. At least not by itself. It's adding maybe 1/10th of a penny to your yearly electric bill. But if it really bothers you for some reason, enter your computer's BIOS setup screens and see if you can find a "wake on LAN" option and disable that. Don't know if that will help or not, but it won't hurt. -Dave
