Comcast compatible with Linksys?
Oct 21, 2004 2 Replies
Warren
When you change the device connected to the cablemodem, power-cycle the cablemodem before plugging the new device into it. That should be all you need to do on Comcast.
Hi Group,
I'm getting cable data access for the first time.
Comcast won't set me up with a router, so I'll have to figure it out after they leave.
Can anyone tell me if there's going to be compatibility issues with my BEFSX41? Also is anyone familiar with Linksys' WCG200 cable/wireless router and Comcast?
Thanks,
-J
Actually you usually need to power cycle the modem and after it comes up the router and then after it is up the computer. THEN all should work just fine. It DOES work without doing all that but not ALL the time.
