Digital Subscriber Line qwest dsl phx area so slow!
Subject Author Date
qwest dsl phx area so slow! Mike 04-14-05
Posted by Mike on April 14, 2005, 6:04 pm
I have had qwest DSL for 2 months now and I cant figure out what is
wrong with it. It is only a little faster than MSN dial up. I can only
get 26-28kbps on downloads. I have an actiontec modem conected to my
Dell 2300 computer via an ethernet cable. On the ethernet card are two
lights, both are orange. The first says 10(green)/100(orange) and the
second says ACT(yellow). I have XP and the firewall is off. No
antivirus is installed, so there isnt another firewall.
I dont know what other information I can share. Is it possible this is
simply the fastest transfer rate qwest can deliver to my house? Ive
tried a different phone jack on the same line and its exactly the same.
Any recomendations and advice would be greatly appreciated because its
costing me nearly 40 bucks a month and its not very fast.
Mike
Posted by Bert Hyman on April 15, 2005, 2:13 am
Point your Web browser at your Actiontec router and go to the Status->Wan
Status page and look at the "Speed (down/up)" which will tell you what
your router thinks the line is good for. You can also see error counters
and other info about the general quality of your connection.
Then try one of these tests:
http://web100.rit.edu:7123/
http://ndt.server.ufl.edu:7123/
http://miranda.ctd.anl.gov:7123/
to get a better idea of how your line is really working.
You can find lots more test sites by Googling on "NDT and 7123"
Bert Hyman        St. Paul, MN        bert@iphouse.com
Posted by Mike on April 16, 2005, 3:29 pm
Thank you Bert. Those tests said I was doing 220kbs outbound and
217kbs inbound. I still only get 26kbs on downloads. Maybe it is a
setting somewhere? Any ideas?
The actiontec wan status says
speed(up/down) 256/256
SNR margin 30/23
Transmit power 14/11
Attentuation 54/63
I dont really know what these mean. TY in advance for help
Posted by Bert Hyman on April 16, 2005, 10:41 pm
Are you ->sure you're not confusing bps with Bps and you're not really
seeing 26KBytes per second on your downloads? That would be just about the
max you could see on a 256Kb line.
Otherwise, try downloading from different remote systems and use different
file transfer methods and utilities. Very often its the site you're
downloading FROM that's the cause of the slowdown, and since your line
tests out OK, I'd start looking elsewhere for the problem.
> SNR margin 30/23
> Attentuation 54/63
Well, it says that you really do have a 256Kb/256Kb line, and the SNR
margin is pretty good.
I have a 1500/1024 line myself with an SNR margin that's frequently worse
than yours and still get solid 150KB downloads.
Posted by Kevin on April 16, 2005, 11:07 pm
> SNR margin 30/23
> Attentuation 54/63
Mike, in your first post you said "costing me nearly 40 bucks a month",
which leads me to think you have the "Qwest ChoiceT DSL Deluxe with MSN®
Premium" service which is $39.99/month. If that's what you ordered the line
isn't trained at what it probably should be. It looks like you may have been
provisioned for the 256/256 level of service instead.
If you signed up for DSL Deluxe (& not Qwest ChoiceT DSL) first I would
suggest you try power cycling the modem (pull the power cord & wait about 10
seconds then plug it in again & wait for it to reboot & connect). After it's
back up & connected do what you did to see the above info, & look at this
line: speed(up/down) xxxxxx (this says what the modem is trained at). If
you have the Deluxe level of DSL it should train up closer to 1536/896.
If your subscribing to DSL Deluxe & the line doesn't train up to something
closer to 1536/896 I think there are a couple of possibilities: 1) your
modem & Qwest equipment at the other end don't think the line the line is
good enough to do faster. 2)Qwest screwed up & didn't provision your line
right.
If you can't get the line to train faster doing what I suggested above &
your certain you ordered Deluxe DSL I'd call Qwest. Make sure they show you
as having Deluxe DSL & that your line is correctly provisioned (I don't
think it is if you ordered Deluxe DSL).
Kevin
Similar ThreadsPosted
qwest dsl phx area so slow! April 14, 2005, 6:04 pm
Earthlink DSL in Denver area August 7, 2004, 8:08 am
Moving DSL jack to different area of house - please help August 16, 2004, 9:24 pm
SBC Yahoo in San Francsico Bay Area block port 80? January 8, 2005, 4:20 am
looking for DSL provider in Brazil (Lago Sul Brazilia Area) December 11, 2005, 9:11 pm
Linksys WRT54G SLOW August 4, 2004, 5:25 am
Verizon DSL Connection Became Slow October 21, 2004, 7:49 am
Slow Download / Fast Upload February 2, 2005, 9:29 pm
DSL upload slow, starts off fast April 1, 2005, 1:11 am
Odd Verizon behavior, fast, but slow May 25, 2005, 6:30 pm
Slow ATT Yahoo DSL Speed with SS5260 September 9, 2006, 10:18 pm
How to fix extremely slow 10Mbps DSL XPSP2 Bell Sympatico Connection April 26, 2006, 6:25 pm
Qwest DSL without ISP? November 25, 2004, 3:00 am
qwest outage April 23, 2005, 1:18 am
Qwest DSL modem compatibility August 12, 2004, 1:03 am
Residential Cabling Guide
Home Cabling Guide
Finally, an instantly downloadable book that saves you thousands in home improvement dollars! Enjoy living in 21st century technology-advanced home while increasing its selling value and competitive advantage on the real estate market. Whether your cabling is for home office or high-tech leisure, you can wire your home yourself or learn "wirish" to speak with your cabling contractors in their language!
Learn More
