On Wed, 13 Sep 2006 07:01:30 -0400 Froggie the Gremlin wrote: | On 13 Sep 2006 07:05:19 GMT, snipped-for-privacy@ipal.net wrotd: | |>On Thu, 07 Sep 2006 11:53:42 -0400 George wrote: |>| snipped-for-privacy@ipal.net wrote: |>|> According to their web site, the higher speed DSL service comes with |>|> "free wireless". No other details are on the site. I haven't been |>|> able to get anything more from Verizon sales other than "it will let |>|> you access the internet from up to 4 computer". Their tech support |>|> does say it is b/g compatible. I presume it is an access point, but |>|> no one at the other end knew that term when I asked if it was. |>|> |>|> Anyone here actually have this from Verizon? I'd like to find out |>|> what type it is. Is it worth using theirs (presumably on a lease |>|> basis) or buying your own (my intention is to get a WRT54GL which I |>|> could customize the programming of). |>|> |>| |>| Its usually a Westel 327w which is a DSL modem, ethernet switch and AP. |>
|>Can it be configured in such a way as to export the PPPoE stream to |>another router, thus behaving exactly as a modem-only device? Or do |>I need to press Verizon to provide a modem instead of this box, if I |>decide to sign up with their service. | | Most of the modern Westells, ones that aren't WAPs, can be easilt put into | BRIDGE mode, allowing previous routers to manage the PPOE streams. BUt when | the bridges router also has a WAP in its midst, that pass-thru function | becomes very difficult... the WAP in almost all cases is also a router (for | obvious purposes). I don't think the WAP, the router function and the modem | are all configurable separately... especiall separating the router function | from the WAP.
It looks like WRT54GL+OpenWRT is needed in at least one of these cases.
