Two Wireless Routers in my home?
Threaded View
I was wondering if I this would work.
cable modem >>>>> Wireless Router (A) >>> computer (A).
                                   V
                                  Wireless Router (B) >>> computer (B)
Can computer B be connected to the internet through wireless router B
and Wireless Router B) be connected to internet by Wireless Router A?
Re: Two Wireless Routers in my home?
SpreadTooThin wrote:
yes, but why only two?
On Sat, 24 Jan 2009 13:54:44 -0800 (PST), SpreadTooThin
Yes.  However, the way you have it will cause two problems:
1.  Computah A and Computah B will not be able to "see" each other or
pass files back and forth.
2.  Computah B will be using what's called "double NAT".  That causes
problems with applications that need to have IP ports forwarded.  For
these to work, you'll need to port forward both routers.
Both of these problems can be avoided by using an access point,
instead of a wireless router for "B".  Any and all wireless routers
can be used as access points.  See FAQ at:
<http://wireless.navas.us/wiki/Wi-Fi_How_To#Use_a_wireless_router_as_a_wireless_access_point
There's also some debate as to how to setup two wireless devices in
the same general area.  Everyone agrees that they should be on
different non-overlapping channels (1, 6, 11) to avoid mutual
interference.  However, whether they have the same SSID is subject to
debate.  Making them the same will simplify connections and if your
client radio supports seamless roaming, will allow you to move a
laptop between the two coverage areas.  However, if your laptop does
not appreciate roaming, it might be a problem.  I prefer using
different SSID's for each wireless device, so I can manually decide
which one is closer or has the best signal.
Jeff Liebermann     jeffl@cruzio.com
150 Felker St #D    http://www.LearnByDestroying.com
Santa Cruz CA 95060 http://802.11junk.com
Skype: JeffLiebermann     AE6KS    831-336-2558
Site Timeline
