Anyone know about TFPT? I'm looking for one to use for flashing firmware. I'm only go to use it once, is should be free. Most TFPT uses IP address, but some uses USB-TTL.
Help.
Hanz
Help.
Hanz
You don't say what OS you're talking about, but you seem to be running Windows.
There's a TFTP client in \\windows\\system32\\tftp.exe on my Win XP Pro system. I don't recall putting it there, so it probably came with Windows.
It is part of XP and Vista, use tftp from the cmd line and the options will appear. Windows gui versions can also be got from:-
I have had more success with these gui versions when trying to flash routers with 3rd party firmware using windows.
Some of these are clients, some are servers, some are both. Depending on what you're trying to do, you'll probably need the client, not the server.
I normally use the little linksys app that jeff posted a link to. very easy.
Adair
