I would like to have the following configuration in my home, but I can't get it to work.
Linksys WAP11 Access point static IP connected to Switch switch also connected to PC1 and DSL router
WAP11 Access point client static IP connected to hub print server is connected to hub
PC1 can print just fine using AP AP client
Linksys WPC54G in laptop mixed mode set (b/g) SSID set to AP WEP correct Network Index correct
WPC54G sees home network and says signal is excellent. Otherwise, I cannot get the laptop to talk to the access point. I can't ping anything on the network, I can't ping the AP. XP SP2 just scans for a few seconds then gives up. No ACT light on the AP when it is doing this.
I have tried without success to talk to Linksys support about this.
What else can I do? Can somebody point me to specific instructions somewhere on the web that would tell how to configure this? This seems like a no brainer configuration.
An AP is supposed to be able to act as an AP to both an AP client and a regular client, correct?
Thanks in advance Mike
