Motorola SBG900 Configuration Problem
I just got a Motorola SBG900 Cable Modem Gateway. I don't have cable internet yet but I connected the modem to my pc via Ethernet and I cannot get to the configuration page. I just get the IE "Page Cannot Be Displayed" error. Motorola Tech Support stated that I should be able to configure the gateway even if there is no cable connected. Can anyone share any info on this...perhaps tech support is wrong and I first need to connect it to cable? I would rather not return it if there is nothing wrong with it.
Saucer Man
The modem gateway IP is something like 192.108.100.1 . I tried it with my IP set to 0.0.0.0 and also 10.1.1.1 and a mask of 255.0.0.0. I checked the cable type. It is ok.
Saucer Man
When I hardcode the cable modem as the gateway and give myself an IP, it works. When I set it to dhcp, I cannot get an address from the sbg900 dhcp server. I get "the rpc server is unavailable" if i do an ipconfig /renew.
Saucer Man
I found the problem. I had the DHCP service set to manual. Once I set it to automatic, it now works fine. Thanks.
Saucer Man
What is your modem's IP address? What is your PC's IP address and network mask?
I would also check if I have the right cable type, ie. straight vs crossed.
David
David Chong
