Configuration problem
May 15, 2006 2 Replies
Configuration problem open original image
I'm working on two 2970s. I cannot get them to ping out, get anything to ping in, or get them to be able to ping themselves.
gi0/1 on both switches is up/up and connected to a working 2924
2970_1#sh run Building configuration...
Current configuration : 1509 bytes ! ! Last configuration change at 15:09:42 UTC Mon May 15 2006 ! version 12.2 no service pad service timestamps debug uptime service timestamps log uptime no service password-encryption ! hostname 2970_1 ! enable secret 5 XXXXXXXXXXXXXXXXXXXXXXXXXXXX enable password XXXXXXXX ! no aaa new-model ip subnet-zero ! ! ! ! no file verify auto spanning-tree mode pvst spanning-tree extend system-id ! vlan internal allocation policy ascending ! interface GigabitEthernet0/1 switchport mode access ! interface GigabitEthernet0/2 ! interface GigabitEthernet0/3 ! interface GigabitEthernet0/4 ! interface GigabitEthernet0/5 ! interface GigabitEthernet0/6 ! interface GigabitEthernet0/7 ! interface GigabitEthernet0/8 ! interface GigabitEthernet0/9 ! interface GigabitEthernet0/10 ! interface GigabitEthernet0/11 ! interface GigabitEthernet0/12 ! interface GigabitEthernet0/13 ! interface GigabitEthernet0/14 ! interface GigabitEthernet0/15 ! interface GigabitEthernet0/16 ! interface GigabitEthernet0/17 ! interface GigabitEthernet0/18 ! interface GigabitEthernet0/19 ! interface GigabitEthernet0/20 ! interface GigabitEthernet0/21 ! interface GigabitEthernet0/22 ! interface GigabitEthernet0/23 ! interface GigabitEthernet0/24 switchport trunk encapsulation isl switchport mode trunk ! interface Vlan1 ip address 192.168.0.251 255.255.255.0 no ip route-cache shutdown ! ip http server ! control-plane ! ! line con 0 line vty 0 4 password defcon13 no login line vty 5 15 password defcon13 no login ! ! end
Why is interface Vlan1 shutdown?
Cisco da Gama
Awww, fer the love of God... :-)
But wait...
2970_1>en Password: 2970_1#conf t Enter configuration commands, one per line. End with CNTL/Z. 2970_1(config)#vlan 1 2970_1(config-vlan)#no shut Command is only allowed on VLAN 2..1001. 2970_1(config-vlan)#
