You still working on that problem... From what I can tell 1.02.7.03 is the latest......here is a link
Have you tried different browsers? I have read that some sites such as yahoo mail, aol and a few others have problems because of the MTU setting of the adapter. To see if this helps search for DrTCP, download it and it will allow you to check and change your mtu. Most PPPoE likes1492 but you can take it down some (like 1400) to test. If running a VPN, it likes an MTU of 1430, DHCP likes 1468.......
