I have a wireless setup in my house, which is a linksys wrt54g which is providing a wireless signal from my adsl connection . Picking this signal up is my pc using a belkin f5d7000 pci card. I also have a dell demension 2400 laptop which is connecting wirelessly to the linksys.
Both connect and I can access the internet, which is the main use of the laptop, but randomly the pc will drop its connection and when I go into view wireless networks, where there is usually 2 networks , there are none. Refreshing doesnt sort this. The only thing that does is a reboot of the pc. As a test I have powered up the laptop when the PC has gone down and it can locate the signals perfectly.
Has anyone any ideas on this ?
Thanks
Jon
