I am trying to set up a used phone system with new extension numbers and voicemail boxes. I have succeeded in re-initializing the TDS95 and getting a VT100 terminal setup. I think that everything works great except that... when an incoming call gets routed to the voicemail box (after several rings unfortunately), it gets routed to extension 199 (?) instead of the custom messages. Somehow extension
199 is programmed to allow the caller to select operator or voice/ email. I have concluded (ie, guessed) that the TDA50 is using a "floating extension number" when it passes the call through. Of course, I don't have the special software or manager passwords to do much with the TDA50 programming. Anybody got any helpful advice... or... any gurus in the Pittsburgh PA area want to help?Thanks for your interest. Help!!!!
--- Mark.
