personailty disk works fine wondows 7 with 32 bit but not 64 was there one made any one have a copy saves carryng 2 laptops
- posted
7 years ago
No however the personality discs only change 4 files and you can copy those from the old installation to the new one
Install Compass on a 32-bit machine then copy Fixed.ldb, System.ldb and System.mda from the \Database directory and Fixed.mdb from the \exe directory to the new machine
thanks
Can't you just execute in compatibility mode?
Tried that doesn't work, Since Honeywell is slowly moving everything to AlarmNet 360 I doubt they will create a 64 bit patch
