Problems with an Ademco Vista-15... System won't arm, and it keeps counting?
Threaded View
Hoping someone might have run into this problem before. I've got a 5-
year old Ademco Vista-15 which refuses to arm.
The control pad -- a fixed-word display -- has a "check" status
indicator on, and the alphanumeric section where I would expect to see
zone data is counting from 49 to 63, then starting over again. (And
over and over and over.)
When tripping the sensors (total of 2 motion + 3 door) the control pad
is correctly identifying the zones that are being triggered. Inputing
the master code to turn the system off, place it in test mode, adjust
other codes, or anything else for that matter seems to have no effect.
Anybody run into something like this before? Could it be a simple
matter of replacing a battery or something? (I couldn't find any
descriptions via Google that matched my problem, so I'm not so sure.)
Many thanks in advance for the help...
Re: Problems with an Ademco Vista-15... System won't arm, and it keeps counting?
I've never seen a Vista 15 do any kind of "counting".
First I'd:
Remove the main system battery
Unplug the transformer and let it sit for a minute, then plug transformer
back in and reconnect the battery.
Could be that zones 49-63 have been inadvertently programmed into the
system. Anyone have the section numbers handy for those zones so he can
check?
*56 but he's gonna need the installer code and a programming keypad to get
there.
| check?
On Tue, 6 Feb 2007 19:32:23 -0700, "Crash Gordon"
** TOP POSTING FIXED **
And he will need a 6160 to see what's going on!  Maybe he can call
Sarasota or Brazil to find a workaround in 120 minutes or less
telephonically.
Unfortunately Sarasota Slime knows diddly about Ademco.  Come to think
of it, he doesn't know much about Napco either.  "Attention Burglar! Go
ahead make my day!"
Frank Olson inspired greatness with:
What good is he then?
I dunno about others, but I usually set my keyfobs to those higher zones. If
you don't have any keyfobs, just disable those zones. And if you have
keyfobs, remember to enable all four (4) buttons, even if you have to set
the fourth one to null. Not enabling the fourth button may give you problem
like you've described.
Have you been messing around with your system lately ? Another thing to
check is if you don't have zone expander enabled by accident but I doubt a
Vista 15 can assign hardwire zones to those numbers.
Many thanks for all of the suggestions. Pretty easy to eliminate a lot
of the options... I don't have keyfobs, and am using a pretty
restricted set of zones with only a few trips hooked in. *grin*
It turned out that unplugging the system and removing the battery to
force the whole thing into a complete reset was enough to do the
trick. Everything is working again.
Again, thanks to all, and especially Crash Gordon who won the booby
prize!
I have it on good authority that Crash enjoys boobies.
I love boobies!
| >prize!
Crash Gordon inspired greatness with:
I knew it!
Yeaaaa  Boobies!!!
does that mean that he gets to see yours, or a new set for himself?
dem boobies is mine...youse get yer own
"Tommy" <tommy at leesecurity.net> wrote in message
| > prize!
damn you Crash, I need a peek too.
On Fri, 9 Feb 2007 21:01:05 -0700, "Crash Gordon"
new header
Women's Poem
 >Before I lay me down to sleep,
 >I pray for a man, who's not a creep,
 >One who's handsome, smart and strong.
 >One who loves to listen long,
 >One who thinks before he speaks,
 >One who'll call, not wait for weeks.
 >I pray he's gainfully employed,
 >When I spend his cash, won't be annoyed.
 >Pulls out my chair and opens my door,
 >Massages my back and begs to do more.
 >Oh! Send me a man who'll make love to my mind,
 >Knows what to answer to "how big is my behind?"
 >I pray that this man will love me to no end,
 >And always be my very best friend.
 > MAN'S POEM
 >I pray for a deaf-mute nymphomaniac with huge boobs
 >who owns a liquor store and a golf course. This
 >doesn't rhyme and I don't give a shit.
ROFLOL
good one
I think that if you really break this down to basics, all women really
want is a credit card with a penis.
Site Timeline
