Help needed MAGELLAN MG5050
Hi Guys;
I've completed my paradox alarm installation (according to manual - I think?) but somehow something is still missing. The keypad keeps on showing message "Zone## open". I have disconnected my expander (SP- ZX8) as well as voice dialer (VDMP3) - but still the same problem. I then disconnected all zones and used an EOL between Zone1 and C (on control panel) but the keypad keeps on showing message "Zone01 open". My multimeter indicated that the zone is closed - WHAT AM I DOING WRONG? I'm almost sure it's a program setting that must be entered...
I'm using the K32LCD keypad.
Is there anyone out there that can help me?
Thanx
alarm_1st_timer
Unfortunately, it's rather difficult to take you through programming "step by step" in a medium such as USENET. If you're having problems understanding programming via the manual, I would suggest that you might be less frustrated by calling in a pro to do it for you.
Frank Olson
Did you program the zones for end of line supervision? If not, you dont need the resistor.
James
James B
