| > I don't know. They have now responded with two different explanations | > (one about different "factory calibration" and another about a new | > firmware format that has the property that if you were to be able to | > downgrade to the previous version it could "damage" the hardware). They | > also said that there are two classes and it's just that you can't | downgrade | > between classes. But that doesn't seem to agree with a message from a | user | > who couldn't downgrade from a beta to the previous real release, both | > well into the second "class." The user is unable to make recordings | longer | > than 38-40 minutes. | | Two different explanations?
Yeah, I would have been happier with one. :(
You can read the thread here:
| The "damage the hardware" theory sounds just like the BS Apple is | spreading about hacks to the I-phone rendering the phones useless after they | issue a SW upgrade.
I have seen cases where embedded flash updaters failed in bad ways for certain combinations of file size, leaving the device in an unbootable state. But in each of those cases the solution was to fix the bug in the next release and to warn users about the bad ones (or bad combinations). And of course, if you know about the problem in advance you could just as well fix the bug (which has to be in the _new_ firmware) as add the downgrade lockout...
| > |Are the DRM police after them? | >
| > I asked that and they said no. They have been adding various phone-home | > "features" which are supposed to be off unless explicitly turned on, but | > one user reported that the device was hitting his firewall with outgoing | > requests 300(?) times per day even though he had never enabled it to phone | > home. The firmware also got a lot bigger recently with no obvious | significant | > increase in user-visible functionality. | | I'm amazed at how quickly HW and SW makers have assumed everyone has an | Internet connection and will gleefully let both talk to whomever they | choose. When I worked in a classified lab, hooking a PC to the internet, | even for a FW bump, would invalidate the unit's security and it would have | to be completely recertified under the assumption that once it's connected | to the WWW, all bets are off in terms of data security. What do the "home | phone" features do for the end user? Or is this just more of nosey | manufacturers wanting to know everything about their customers, even if | those customers don't want to participate knowingly in their data collection | efforts?
My understanding is that they are trying to create a channel lineup database by combining information on what channels are available in each area where an HDHR is operating. I think this is used by some software on the PC for PVR/guide functionality. (I use my own software so I'm not sure exactly what's supposed to happen.)
| > I find it hard to believe that they do not understand the debugging 101 | > rule that says that if a change breaks something the first thing you test | > is undoing the change. They claim that all firmware releases are | completely | > backwards-compatible so you never need to back out an upgrade, but this | was | > certainly not true in the past. I think they must have a really good (for | > them) reason for doing this and I'm concerned that it will turn out to be | > a bad reason for users (beyond the debugging issue). | | I suspect you're entirely correct. I would suspect they've added something | to prevent recording of material broadcast with the "no copy" flag set, but | they're not a recording device, per se, although it's obvious that HDHR | owners will likely be recording programs as VCR owners have been doing for | decades.
The primary use of the HDHR is as a tuner for various recording software, so yes, I'd say it is likely that owners will be recording programs. :)
| > I was never really comfortable with the encrypted firmware (preventing a | > quick "strings" from showing the latest command changes) but I understood | > they want to protect their intellectual property from reverse engineering. | > Taking that in combination with this new change, though, I must | regretfully | > withdraw my recommendation of the product... | | Perhaps someone figured out how to break their encryption so they've moved | to a stronger protection algorithm.
That's a good possibility that did not occur to me, though I'm not sure why anyone would care about breaking the encryption as long as the firmware wasn't creating DRM problems.
| I just | got a hi-rez LCD TV only to discover that nearly every HDTV signal I get on | my Comcast connection is 720, not 1080, so I've got black bars everywhere!
The black bars aren't there because of a resolution mismatch but because of the horrible mishandling of aspect ratios. A number of my OTA ATSC stations broadcast always claiming 16:9. When they have 4:3 material (which is a lot of the time) they pillar-box it. When displaying this "16:9" content on my 4:3 TV the default is to letter-box. So I get black bars all the way around a little 4:3 picture on a big 4:3 screen. Fortunately, some devices have an option to expand the 4:3 picture-in-a-picture to full screen. The other night I was confused that none of the usual selection of options was giving me the expected result. It turned out that they were broadcasting actual 16:9 content letter-boxed in a 4:3 window which was then pillar-boxed in their standard 16:9 format!
Dan Lanciani ddl@danlan.*com
