Sorry if this is a dumb question but I haven't been able to put it all together yet and thought I would ask you fine folks here :)
I was wondering if I could have my wireless router Linksys WRT54G support both DHCP Dynamic Ip assignment as well as a static ip's in the same network. My reason is simple, my new employer which provides a laptop for support uses only Dynamic assigned address through their network and I would like to use my broadband connections which is connected to my own personal network which I have static Ip address assigned. Is this possible to mix the two types of ip assignments under one router (or two). I also have another router Linksys BEFSR41 which I am willing to integrate into the system to accomplish the task if need be.
Any thoughts?
FM
