Hello,
I'm using Kerio Personal Firewall 2.1.5.
When I ssh in from another computer, I am prompted for incoming TCP to port 22, connecting to c:\\Path\\Of\\SSHD\\Server from The.Remote.IP.address. So I created a rule for exactly that, except that I specified that the allowable remote IPs to be
Network Address: xxx.yyy.zzz.www Network Mask: 255.255.255.0
From confirming on usenet, this specifies IPs where www ranges from 0-255. This is the behaviour that I wanted, since, the IPs are assigned dynamically. It also seemed to work fine at the time that I created the rule.
However, it stopped working today. I specified the IP address as a range, and it started to work again. Then changed to back to network/mask -- still continued working.
Any ideas as to what might cause this?
Thanks.
