In article , Rich Noonan wrote: :I'm looking for a device which could act as an ethernet breaker switch :based on the application or loss of power to that device. On one hand :we could accomplish what we need with a low-cost switch and two cables. : However, in our application and environment this would introduce :several new problems. What I really need is a two port fast ethernet :repeater that I could cut power to and break the link. Of course, such :a thing doesn't exist (or does it?).
Your reference to "several new problems" makes it difficult for us to know what would be acceptable and what would not.
I don't know whether this will help you, but recently I have been investigating remote-controllable serial ports and remote controllable power switches. For my particular application, I was looking at ones that can be reached via ethernet. Especially for the power switches I also found devices that can be controlled via serial lines -- up to 2000 feet for one of the devices.
Typical remote control units have 1, 8, or 16 ports, with 4 and 32 port units not too hard to find, and with 2 port units available but not easy to find.
The choices are differentiated on their remote access method (serial / ethernet); their security (ssh?); their modularity; their flexibility (several are uLinux with SDKs); their number of ports; their physical size; the amperage the power controls handle; and, of course, upon their cost.
Links to several manufacturers can be found at
In addition to those, I suggest checking out
their web page has not yet caught up to several recent security enhancements.)
I have several other units bookmarked; if you want a bookmark dump, send me an email note.
