when configuring etherchannel on 2950 to another 2950 that already has a linkto each other using port 1 on each switch, does it matter if the cabling is set up first before the ports are configured and turned on? also can i use the existing ports 1 on each switch that are the current trunk link. in other words what are the physical steps in the process. i know the cli commands, but it would'nt hurt if someone also added them just to ensure my configs
thanks le
