Etherchannel problem
Apr 27, 2006 7 Replies
Jump to replies (7)
Hi group. I have an issue whilst trying to set up an etherchannel between a 6513 and 6509. As soon as the Channel is up and bonded a switch in an external office (Cat.3650) goes off line and only a reboot of this external switch will bring it back with the Port Channel shutdown. The default gateway of the remote netowrk sits on the 6513, the external switch is just in default setup with ports set to cisco-desktop macro.
Port Channel set up below:
6513: ......... ! interface Port-channel1 switchport switchport access vlan 4 switchport trunk encapsulation dot1q switchport mode trunk ! interface GigabitEthernet13/1 switchport switchport access vlan 4 switchport mode trunk channel-group 1 mode desirable non-silent ........
6509: ....... interface Port-channel1 no ip address switchport switchport access vlan 4 switchport trunk encapsulation dot1q switchport mode trunk ! no ip address switchport switchport access vlan 4 switchport mode trunk channel-group 1 mode desirable non-silent ...
Any ideas?
Thanks J
Is the connection a trunk or not ?
If is is then lose the "switchport access vlan 4" command and get rid of DTP - configure the trunk as nonegotiate
Thank for the prompt reply. I am assuming it should be a trunk, I was just trying to allow the channel to pass only traffic on that vlan.
So should i enter:
no switchport access vlan 4 switchport mode trunk nonegotiate
Thanks J
So should i enter:
Thanks J
What is the status of the 3560 port that is connected to the network? Is it err-disabled? If so, what is the cause?
If you only want vlan 4 on the trunk use switchport trunk allowed vlan otherwise use switch trun native vlan or something like that.
URB
try
! 6513 port channel configuration
no int po 1 no int gi 13/1
interface Port-channel 1 description trunk between 6513 and 6509 no ip address load-interval 30 switchport switchport trunk encapsulation dot1q switchport mode trunk switchport nonegotiate switchport trunk allowed vlan 4 ! permit only vlan 4 traffic across trunk no shutdown
interface GigabitEthernet 13/1 description trunk between 6513 and 6509 no ip address load-interval 30 switchport switchport trunk encapsulation dot1q switchport mode trunk switchport nonegotiate switchport trunk allowed vlan 4 channel-group 1 mode on no shutdown
Thanks for this. Works a charm. I am trying to understand the load balancing aspect. I have many hosts going to few servers. From my reading it looks like port-channel load-balance src-dst-mac would work best.
Do you agree? Thanks again
I am not sure of the best load balancing algorithm as I have never tested.
You can configure load-interval 30 on each of teh interface you place in a port-channel to be able to get a better idea of their instanteious utilization
