Hi, I took the 640-801 and failed by 5 points. Does anyone know how to check for the default gateway on a switch (2950). I tried doing a:
#show run
But could not find it on the following config:
RTR--SW-SW--host
Thanks.
#show run
RTR--SW-SW--host
Thanks.
if there is a dg configured you will see it when you do a #sh run. If there is not one just do the following from global config mode "ip default-gateway [ip address]"
