WRT54G LED happy?
Jun 09, 2006 2 Replies
Jeff Liebermann
Not normal. They might flash ocassionally or more often when you're doing something on the internet, but not continuously. That means whatever computah you have plugged into port 1 is either downloading a bunch of stuff from the internet (assorted updates), or spewing crap all…
I've got a WRT54G router here and i just noticed the Internet and 'Ethernet 1' LEDs blinking fast as strobe lights. Is this normal?
Not normal. They might flash ocassionally or more often when you're doing something on the internet, but not continuously. That means whatever computah you have plugged into port 1 is either downloading a bunch of stuff from the internet (assorted updates), or spewing crap all over the internet because your computer is infected with a virus or worm. Update your virus scanner and scan your machine for virus's.
On Fri, 09 Jun 2006 04:40:14 GMT, Jeff Liebermann wrote in :
