WPA for WET54G
Mar 16, 2005 2 Replies
Hi all,
Does anyone know if there's a patch/update to enable WPA on the WET54G (European version)?
Thanks in advance.
Regards, Peter
I believe that if you have a WET54G ver.1 the hardware is such that it cannot be upgraded to WPA by a firmware upgrade.
Hmmm, bad news then... Would a hardware upgrade be possible? The problem is: I would like to introduce strong authentication (via Radius), but I won't be able to do so, unless I get rid of that WET54G
Thanks for your answer, though...
Regards, Peter
