I have an old laptop that only has USB 1.0. Will any of those USB dongle thingies allow me to connect? (I'd rather not do a pcmcia card.) thanks
Wireless USB for USB 1.0?
May 24, 2006
Hi Even if a the device is USB2 802.11g it is downward compatible. Jack (MVP-Networking).
Read the full replyHi Even if a the device is USB2 802.11g it is downward compatible. Jack (MVP-Networking).
you'll top out at 11or12 MB/Sec due to USB1 but apart from that it should be fine.
gR
USB dongle working fine with USB1 here.
thanks all
correct! used a big b when I should have used a small one!!
thanks
"gerryR" hath wroth:
Make life easy so nobody has to guess. Write it out as in: xx bytes/sec and xx bits/sec and never mind trying to invent a new abrev.
