I am thinking of buying this Linksys adapter, which covers (802.11b and g), but I will be moving to Europe soon - Spain-Portugal area.
Is this 2.4 GHz band also available in that part of Europe and in UK and Ireland?
TIA
rf
Yes except that if you buy in the US and then come to the UK, you might be unable to connect if the AP is on channel 13 or 14 which the US card/drivers/firmware won't let you connect to as that regulatory domain doesn't permit these channels. David.
Read the full replyI am thinking of buying this Linksys adapter, which covers (802.11b and g), but I will be moving to Europe soon - Spain-Portugal area.
TIA
rf
David.
Thank you David for the alert.
I'll check into it.
rf
I just found a very interesting Cisco web site - about Aironet:
There is also info about a World Wide Mode
"Enabling and Disabling World-Mode When you enable world mode, the access point adds channel carrier set information to its beacon. Client devices with world mode enabled receive the carrier set information and adjust their settings automatically. For example, a client device used primarily in Japan could rely on world mode to adjust its channel and power settings automatically when it travels to Italy and joins a network there. World mode is disabled by default."
which mentions Italy - in Europe.
There is another page at:
Can you help decipher what is going on?
tia
rf
Seems like I have a blind spot somewhere.
EMEA = Europe, Middle East & Africa.
David.
EMEA????.....
Thank you David. Is there anything you don't know :-)
rf
inappropriate flattery, way too much that I don't know. I just happen to work in EMEA ;)
David.
Great to find a person who knows where he is :-)
rf
Well I can narrow it down a bit more if pushed ;)
Does virtualearth.msn.com "locate me" work in EMEA? Kinda spooky.
Yes it does but it shows the whole county rather than my office in the house which is a little disappointing I think. :)
It should have sprouted a popup that said you were located by IP address, which might be your ISP, or it just defaults to the center of the country, although it picked up the right country ;-)
I think it works via a couple of databases. The cleanest is a table of WAP MAC addresses that has apparently been entered somewhere, although I've never heard of it.
Another is a compilation of what searches have been done originating from particular IP addresses, with an assumption that most zip-code-based searches are local.
Near my work, an open WAP pinpoints the location exactly. The fact that it is a wireless company probably lends itself to solution #1, a deliberate entry into some database.
