Wierd Vista Access point problem
Apr 04, 2007 0 Replies
I have a Netgear WNR854T router set to N for use with my Macbook Pro - works great with a 144mb connection.
Attached to one of the LAN ports or the router is a Edimax 54mb access point also works great......
I use the 54mb so a Vista Home Premium laptop (b/g) can get access without using my N network (or having to switch it to b/g).
I have tried everything to make the Vista machine log on to the 54mb AP automatically - sure the Vista machine see both, but even though I have set it up to log on to the 54mb point, it always tries to connect to the N network - failing.
I then have to connect the Vista machine manually to the 54mb AP and it works ok.
I was already considering removing Vista and putting XP Pro on the Laptop (it was bought new with Vista on it) - because IMHO I think Vista is not worth the hassle - so does my wife who's laptop it is.
Does anyone have any ides why it would do this, or is this just another Vista 'bug'
Clive
