Very Poor wireless range on my Belkin F5D7230-4 wireless router
Mar 07, 2005 2 Replies
As stated before...
belkin is broken
Hi, Using my X5 Dell, next to the router I get an "excellence signal", 5 foot away and its down to "good" and in the next room its "marginal", which is only 7 foot through a breeze block wall. Before you asked my walls are not lead lined.
I'm using the router only as a wireless access point connected to another modem/router. I've tried most channels 1 to 13 with no sign of improvement, and protection is off.
Are my results typical with this device or can any suggest how they could be improved. I've tried positioning the unit as high up the wall as I can. If a no go which wireless modem/router could your recommend, coverage indoors only needs to be on a radius of 50foot max.
TIA
DaViD
*********************** One sees great things from the valley, only small things from the peak. - G. K. Chesterton
Thanks Smowk.
Can't find any previous references you've made to a Belkin being broken.....
But I'm returning it anyway
Smowk wrote:
