USB Wireless adaptor crashes XP
Apr 08, 2005 2 Replies
machine;
Not sure, but I have the same problem with a USB mouse and Win2000. Seems I read that there were some USB fixes for XP in SP2 but I dont remember exactly what they were for. Are you runing SP2?
Hello, members and moderators!
I purchased two Encore ENUWI-B-SICA 802.11B Pensize adaptors
for my two PCs with Windows XP_PE installed, and these little things
perform very nicely and fast. The only thing that surprises me is that
after a while, say about two or three hours of surfing the Web,
suddenly
the PC in turn stops working and Windows shows a blue screen stating
that it has shut off the system in order to avoid further damages to
it.
Besides, the cause is reported to be a "bad page call" or something
like that plus some parameters unknown to me. It also recommends
that if it is the first time it happened, I should restart the machine;
otherwise, I should check the hardware installed, etc., so I have to
turn off and restart the machine in order to resume my navigations..
and there! it happens again.
This phenomenom occurs exactly in both PCs which incidently have
different motherboards, one is a Compaq 5WV233 and the other one
is a PCCHIPS M810LMR, both in perfect operating conditions.
Previous to this, I used to have two Wireless PCI cards of different
makes installed in both of my PCs and which worked flawlessly for
hours and hours on end without any problem whatsoever but I had
to give them to my son, and now that I wanted to switch to these
little gems, this problem has arisen.
Does any one of the members of this forum have any idea about what
sort of conflict is happening between this USB adaptor and my PCs and
if there is any solution to that? I'd hate to throw them away!
Thank you very much in advance for any comment/advice that you
may want to add here.
Ruben.
I have found that if a USB adapter fits loose. If it looses it connection for a moment will do this.
