Two routers and StrongDc++
Mar 17, 2006 1 Replies
I've been using StrongDC++ for a while, and it worked very well. I had a router, and forwarded the TCP and UDP ports to the ones used by the program(1100 TCP and 1100 UDP). I also used a DynDNS account for a Dynamic IP.
Recently i installed a wireless router. The wireless router is connected to the old router, which is connected to the phone cable.
Now StrongDC++ obviously doesnt work. What kind of port forwarding(s) do I have to do in order to have it working again??
Any other changes??
THANKS in advance
Either go buy a standalone wireless access point and plug it into a LAN port on you wireless router.
Or configure the wire/wireless AP router to just be a wire/wireless AP
*switch* and plug it into the LAN port on the router, which a router becomes a switch when DHCP on the router is disabled.
It doesn't matter what brand name of the two routers, as the principles of connecting the two routers are the same.
Keep it simple and be done with it.
Duane :)
