Toshiba L110-117 and wireless aerial on-board.
Feb 15, 2006 0 Replies
Hi everybody!
A while ago I bought a Toshiba L110-117 laptop without built-in wireless LAN adapter. Recently, I decided to add wireless card based on mini PCI bus. My problem concerns aerial. I'm not sure, if there is any aerial (antenna) built-in into the LCD screen of laptop. I do not want to open and disassemble the device unless becomes clear that there is one built-in. What do you think? Might be some of you have had similar troubles ... How to check it in the easiest way and if there is nothing like that inside, what can I do? I have heard something about aerials to be placed inside laptop casing.
Regards, Peter.
