To make a wired network cam wireless
Mar 09, 2006 2 Replies
I've one wired network cam that sure would be nice sitting in a spot were it's hard to get a cat5 to. There is one wifi cam in that area, very nearby - almost be nice to bridge a switch and wire both cams from that. Always doing some changes here - a multipurpose bridge/AP might be nice but I'm cheap - $25 extra wont matter though?
Recommend me something that you know works. Single Bridge or multipurpose do-it-all something. Need basic wifi-g WPA - Going to talk to the home ActionTec verizon wifi modem/router.
thanks
if it is a webcam attached to a computer you can go the webcam over your network with a remote access program like vnc.
thanks but no, its a network camera ... stand alone camera with an embedded server and single mac/ip/ethernet port. I'll just order one of the multi mode wifi access points - guess not many have experience enough to recommend anything other than the standard router/ap's in the group here.
