Is it possible to set up a security camera outdoors over wifi for around fifty to a hundred bucks?
Jul 17, 2023 Last reply: 3 years ago 14 Replies
invalid unparseable
You cannot get high resolution videos over WiFi. I have tried that. Anything over 720p will be choppy. Even 720p will be choppy if not close to the WiFi router. You should consider using network cable to connect the security camera to your router.
I don't want to spend a lot. But I'd like to have a closed circuit camera.
I guess it would be event driven. And it could be checked by the home computer.
I don't want anything on the net. Just on my own network.
I have a normal Wi-Fi router.
Any suggestions?
That's good advice at this stage when I'm deciding what will work best, as I'm not trying to get fancy but it has to be good enough to recognize license plates and faces I would think, in case of a recordable event.
An advantage of the cable is it is its own POE which I think can go around
300 feet which is probably twice as far as I need to go.
How do they store the events? Can they do a day? A week? A month?
Most store via an SD card or to your hard drive or ISP.
Depends on your storage size.
128GB SD card: 4 days @1080p 128GB SD card: 24 days @480p
Most surveillance cameras are configured to record only upon motion detection, to save battery and storage life. But you could hook the camera directly to AC power to record until you run out of storage.
One of the simplest options is to put one of those cards in a USB camera. Then you can use an ethernet to USB dongle to power it long distances. The watertight housing can be as simple as a pickle jar.
Maybe a Raspberry Pi camera in a transparent watertight container. Since the RPi has USB, you could also use a USB camera you like. There are even POE to USB adapters for more options to power it.
A Raspberry Pi is $35 for the 1 GB version ``(but spend a little more for the 2 GB or the 4GB).
I use these.
're indoor and outdoor. I only use them outdoors.
They're WIFI and I would never use a wireless camera indoors. It records audio as well.
Amazon.com : WYZE Cam OG 1080p HD Wi-Fi Security Camera - Indoor/Outdoor, Color Night Vision, Spotlight, 2-Way Audio, Cloud & Local storage- Ideal for Home Security, Baby, Pet Monitoring - Alexa & Google Assistant : Electronics
However, the only way you can get "events" (audio and/or video) is with their online service. But it doesn't cost anything and the videos are stored in the camera with an SD card. Not online. You can configure it to record continuously or only record events. You get the events regardless.
You can access the video on the SD card online. I was able to watch what was going on around the house while we were on vacation. What I like the most is being able to specify a detection zone and its sensitivity for events. It notifies you online in real time with the Android app when there are events.
You can have a conversation as well. I've never used that.
You can't use ethernet for the video. You would have to have WIFI. Maybe a show stopper. You have to get a third party POE adapter. Wyze doesn't have one.
I've had them since 2018. They work OK. They're not the high end but they're pretty stable. Day and night.
I think the op wanted something that didn't send the video to a 3rd party.
I think a simple USB webcam (4MP video (2560x1440) at 30 frames/sec for $36) under a small aquarium for rainproofing would work fine.
To get the USB delivered as far as 150 feet, use one of these for $16.
That's $52 -- very close to the original lower price limit. And it has a nice 5 to 50 mm lens.
Because it is USB, all of the free motion-detector software can use it, and store the videos on his computer.
If you want a super cheap camera an ESP32 cam may be the way to go. It needs wifi but the ESP32 cam is prolly the cheapest setup possible.
Here's a video of a guy walking through the ESP32 cam setup.
How to setup and use ESP32 Cam with Micro USB WiFi Camera - YouTube
However they're crap. They're like buying a dancing bear on the cheap (it's not how well the bear dances, but that it can dance at all).
An advantage of a real camera is to catch license plate numbers.
Those services that save in the cloud (such as Wyze, Nest, and Ring) tend to blur out the license plate numbers for a reason unknown to me, but as a result, they're often not useful for security cams that face the road.
However, that little ESP32 camera does not have the resolution or speed to capture the plate number anyways.
A 4k video camera would be nicer, or a still camera with even better resolution in motion-detector mode. But they're prolly more than $100.
Nick Agostini snipped-for-privacy@hughesnet.com wrote
You can get a Hikvision LPR camera:
And then have it record footage to a local BlueIris server:
Another option, although above a hundred bucks, is a POE camera.
REOLINK 12MP PoE IP Camera Outdoor, 93° Wide Angle Dome Surveillance Cameras for Home Security, Human/Vehicle/Pet Detection, 700lm Color Night Vision, Two Way Talk, Up to 256GB microSD Card, RLC-1224A
Charles Jack Jones snipped-for-privacy@cjj.com wrote
I wonder if an old Android phone with a motion detector app can work?
My camera has an option for uploading to the cloud, but that is optional.
I have a 256 GB microSD card in it, and I can access the camera using my local intranet. It was $110, which is outside the OP's target price, but I wanted the 12 megapixels to see license plate numbers (day and night).
Given they're made for cars, the OP might consider a cheap $50 dashcam.
Another option is to connect a Tesla coil to the vehicle that only activates when you park it out of the way. Non-lethal, non-damaging, but surprising and unpleasant. Along with the flashlamps and sirens.
Even better is to rig a can of spray paint and some mace. :)
The camera I have is this one, which costs about $110 each.
Since that's over the OP's budget, this one one is cheaper.
has a 3x zoom lens, but a lower resolution camera (4k is still pretty darn good for basic security needs).
Either one would typically work in normal day/night security norms. If that's too much money for the OP, this should work
I have no experience with it).
It is only 5 megapixels (2592 by 1994 pixels) but that is still better than high-definition television. They have free returns if it doesn't work out for the OP.
I would suggest a 4mm lens instead of the wide angle (2.8 mm) lens. This will go a further distance which is often needed in such cameras. And the bullet form will probably be better than the turret form.
The OP can put in a microSD card and it uses a POE & CAT5 cabling. The OP will likely want to connect it directly to his home router. It will probably involve drilling a hole in the wall to get outside.
Does anyone else have experience with these security camera setups?
Thomas snipped-for-privacy@gmail.com wrote
I had bought this only a month or two ago.
It's a Wosports G100 Trail Camera. 16 Megapixels (5376x3024 Day and night mode (lots of IR LEDs). Motion sensor.
I have it locked with a six-inch Master lock holding it onto a steel post.
I would have bought the better one for another $3 had I seen it first.
looks like it has the same mounting holes that fit the long-hasp lock.
