SMC 2802 Wireless PCI Card
Sep 23, 2005 1 Replies
How can I get the SMC 2802 Wireless card to work properly under Windows XP Professional. It has to connect to a US Robotics Access Point. The drivers are allready installed and working properly. The network "WIRELESS" is found. It just cannot connect.
For security we use a mac address filter. Every other computer can connect, accept the one with the SMC 2802 Wireless PCI Card. We also tryed different SMC Wireless cards (2602 and 2402) but that cards will not connect either. Other cards like Asus or US Robotics do connect perfectly.
Thanx in advance,
Erik Metselaar
Does it work if you turn off the MAC filter? If so then it sounds like the MAC address is wrong, try an IPconfig /all and see if it's the same as the label or maybe you're misreading it off the label?
David.
