simple question
Jan 31, 2006 7 Replies
Jump to replies (7)
what is the access code to program my router manually...I know the pass word is admin....
That would be specific to your router. Most come with no username and a password of admin. If a username is required, it is usually admin as well. You should change the default as soon as possible.
uh.....what kind of router do you have?
uh ... did you read the manual or go to the vendor support website?
uh ... did you try a Google search?
Not to be harsh .... but
1) you need to give details when asking hardware or vendor specific questions
2) you should post questions after you have done some basic research / read the manual / go to the vendor website
Simple answer: It's whatever you set it to. If you didn't set it to anything, it's probably still the manufacturer's default.
Ask a silly person...
"Mindy" hath wroth:
The default IP address is 192.168.1.1 Point your web browser to: http://192.168.1.1 The login and password are both "admin".
NO username required
Password is 'admin'. CHANGE THIS!
