RSSI measurement
Nov 06, 2007 1 Replies
Hi, I have a few Cisco Aironet 1240 APs. If someone knows how to start a radio test & receive the test results - please share. Radio test involves, RSSI measured ffrom each AP from a particular designated AP. Is there a suggested way (SNMP/CLI)?
Thanks..
~ Hi, ~ I have a few Cisco Aironet 1240 APs. If someone knows how to start a ~ radio test & receive the test results - please share. ~ Radio test involves, RSSI measured ffrom each AP from a particular ~ designated AP. Is there a suggested way (SNMP/CLI)?
You want each AP to tell you the RSSI of the signal that it is receiving from each *other* AP? This functionality is available if and only if you are using a Wireless LAN Controller (WLC).
With autonomous IOS, from each AP, you can see the RSSIs of any associated clients, via the command 'show dot11 associations all'.
Aaron
