Problem when using 2 APs WAP54GP
Mar 15, 2006 5 Replies
Jump to replies (5)
I am setting up a network with 2 APs WAP54GP connected with a hub.
AP1 HUB AP2 | PC
The AP1:192.168.1.241 and AP2: 192.168.1.242. I am using different SSID and different channels. Then I have one PC connected to the hub and one laptop which I connect to the wireless AP1.
First I connnect the laptop to AP1:
Laptop AP1 HUB AP2 | PC
The connectivity is fine and I can ping the AP1, AP2 and the PC. Then, I disconnect from AP1, I move the laptop to the AP2, and I connect to AP2.
AP1 HUB AP2 Laptop | PC
Here is when I start to have problems. The connection to AP2 is fine and I can ping it. But, I cannot ping the AP1 or the wire PC. This problem happens during 15 minutes, and after this time period the connectivity is back. It seems that it is a problem with an agingtime that blocks the AP from forwarding traffic.
After putting a sniffer in the laptop and the PC, I could tell that the traffic is forwarded by the AP from the wireless to the wire but the traffic from the wire to the PC is not forwarded to the wireless. This means that any arp sent by the laptop is seen in the wire, but any arp reply is not sent to the Wireless.
Now, the question is why does AP block the traffic only in the wireless direction.
Any hint on solving this issue? Is this a bug on linksys?
After chatting with linksys support online, they could not give me a solution and they did not consider it a bug!!
Regards, Pedro Pereira
snipped-for-privacy@gmail.com hath wroth:
Duh. It shouldn't do that unless it's blocking all broadcasts.
Try a few experiments. I'll assume Windoze XP SP2 Home.
  1. Connect to AP2. Run: Start -> Run -> cmd ARP -d * (flush the entire ARP table) Now, try to ping everything again.
  2. Connect to AP1 as you did in the first case that worked. Ping everything to be sure it's still working. Run: ARP -a and record the results.
Now move to AP2 and run: ARP -s ip_address 00:aa:bb:cc:dd:ee for AP1 and the PC exactly as it appeared in the "ARP -a" listing. You don't need ARP broacasts if you can supply them manually.
If that works, then you've found a nasty bug in the Linksys firmware (which you didn't specify the version). If it doesn't work, then the problem is somewhere else, possibly a MAC address filter in the access point.
Looking at the WAP54GP setup at:
find lots of potential probelems:
  1. I notice that it supports RIP (router information protocol). Make sure this is off as it may cause entertainment value.
  2. Make sure you did *NOT* clone the MAC address of the PC or you'll have identity problems. That works fine with a router, but gets messy with an access point that doesn't have the WAN-LAN isolation of the router.
  3. This is the first access point I've seen that has a firewall. Turn it off:
  4. The WAP54GP has a DHCP server. This is my guess as to the most likely culprit. You should only have ONE DHCP server on a system. Turn off one of the DHCP servers in either AP1 or AP2.
Hi Jeff,
Thanks a lot for your answer. I will try the arp -s command. This could be a very good test because it could be that the AP is blocking the arp to the wireless interface (you never know).
The firmware that I am using is the latest one on linksys web site:
1.24 (it is the one that comes with the AP, so I never updated it)
Regarding the WAP54GP, I guess that you have mistaken it with WTR54GS. The one I have it is a very simple Access Point, and it does not support any features such as RIP or dhcp server.
I am quite sure that the problem is not with the arp because I can
Sorry ... hit the reply button by mistake! :-)
as I was saying, I am quite sure that the problem is not with the arp on the PC because I am able to ping it before the connection to the AP2 and after the 15 minutes period, I can also connect. It can be a problem with the arp table in the AP, but I cannot clear it!
Regards, Pedro
Oops. The list at: |
a WAP54GP2 and a WAP54GP2A-AT. Somewhat different firmware. The WAP54GP2 seems the more reasonable guess.
So, let's go down my previous list (again):
  1. It has RIP: |
    sure it's turned off.
  2. It apparently does NOT do MAC address cloning, so that's not an issue.
  3. It apparently does NOT have a firewall, so that's not an issue.
  4. It does have a DHCP server. Make sure there's only one DHCP server in the system. If there's a router somewhere in your LAN, use its DHCP server. |
    is my best guess as to the cause of the problem.
Hi Jeff,
The closest to my WAP54GP is
. Again, this one does not have RIP or DHCP.
Pedro
